This may help to select topology based on power levels.
- All the basic protections like short circuit, Reverse polarity.
Protection against input voltage with reverse polarity is independent of the converter's topology. You can build a simple reverse polarity protection with a MOSFET (ideally, PMOS) and a few passive components. However, if you want something like "protection against applying voltage from output-side with even reverse polarity" don't laugh, you can see such requirements in automotive then things may change.
- No power consumption when no load.
There's no such thing as "no power consumption at no-load". There should be some acceptable power levels. For example, EU 2019/1782 ANNEX II defines the maximum allowed power consumptions for different power output levels (including no-load). So you should explicitly specify the no-load power consumption.
Anyway, here are my thoughts:
LLC converters are a bit problematic at no-load regulation. So I'd not go for LLC. But if the controller has some magic inside for no-load regulation then LLC may be an option.
Flyback could be another option. But flybacks are terrible in terms of EMC performance. Though you didn't specify any EMC requirements so I don't want to say anything extra about this.
I'd go for either two-switch or active clamp forward converter.
