I bought an ExpertPower EXP-1270 12v 7Ah battery, and I want to know how to charge it. I don't have a battery charger, but I want to do it with my variable power supply. I had already set it to 13.8v, but after charging for an hour or two the battery had only reached 13.2v. Am I doing something wrong?
I want to use the battery for general purpose where I can charge it, disconnect, and then use it for whatever I need to. When I'm done using it, I will recharge it again.
The battery has several specifications, including two voltages:
Standby voltage 13.7-13.9v
Cycle voltage 14.6-14.8v
Current limit 2.1A
Constant Voltage Charge
12v 7Ah
20HR
How should I charge it? I'm used to charging lithium batteries that don't take long to charge.
I'm just looking for what voltage and current I should use, and how long to charge for.
