I'm designing a simple circuit which will charge a big capacitor for 3 seconds, then pass a 5A current for few microseconds, then charge again the big capacitor for 3 seconds, then pump again 5A for a few microseconds, and so on. And now I test it on a breadboard and I'm convince that its working. So I started to do a PCB layout.
Questions are the following:
  1. Do I need to concerned on the EMI emission?
  2. What design techniques can you recommend to me or PCB guide layout on this specific PCB.
  3. Any precaution that I need to do in the circuit or even PCB layout?
    \$\begingroup\$ Sharing your schematic will help formulate good answers. Also, is the circuit going to pass 5 Amperes "for few Microseconds" or "for 3S"? Contradictory information in the question. \$\endgroup\$ Commented Jan 31, 2013 at 5:35
  • \$\begingroup\$ Is 3s the repetition period of pulses? \$\endgroup\$ Commented Jan 31, 2013 at 6:00
  • \$\begingroup\$ It will pump 5A for few microseconds and this scenario will be repeated after 3S. \$\endgroup\$
    – jasp
    Commented Jan 31, 2013 at 8:38
  • \$\begingroup\$ It will better if you can explain more about the schematic. Could include a capture of the schematic? \$\endgroup\$ Commented Jan 31, 2013 at 10:58
  • \$\begingroup\$ What is the different between 2nd and 3rd question? \$\endgroup\$ Commented Jan 31, 2013 at 10:59
1.- Yes, sure. You always must attend the EMC performance of your electronics design.
EMC or Signal Integrity, we are talking about the same. Although probably It's a hobbyist-project and you won't need to pass an emission or immunity EMC test in a EMC Lab but EMC is also the noise, the crosstalk or ground bounce and this could be a problem inside your project.
So, yes. For emission you can check: (only a summary)
  • Raise/Fall Time in high speed signals.
  • Layout of high speed. (Changes of layers, loop current...)
  • Possible antennas. (Your connector and your cables could work as an antennas)
2.- It would better if you explain us more about your circuit.
I suppose there is a component that works as a switch. The out of this component we can call it "switch node". In this node the voltage is
$$V = L (di/dt) $$
; V is voltage, L the inductance of the node, i is the current, and $$di/dt$$ is the rise time (or fall time) of change.
This parameter is really important!
Maybe you can:
  • Decrease the rise time. (Could it work slower?)
  • Decrease the voltage (Could you use a lower voltage?)
  • Decrease the inductance in your switch node.
  • Include a snubber (a circuit for absorb the voltage peak).
3.- This question is the similar to 2 isn't it?
Some additional tips for PCB design in EMC point of view:
  • Try to keep conductor loops as small as possible (usually can be followed when using optimized and short conducting routes). See: Electromagnetic induction.
  • Try to avoid 90 degree "corner" turns in PCB conductors as the signal may "bounce" in tight turns -> can cause EM-interference. Good way is to use 45 degree turns.
  • Do not use too narrow conductors especially in power line conductors (VCC etc.)
  • Try to have good ground (GND) plane and grounded in multiple points -> reduces EM-interference
  • Use EM-radiation against itself: keep forwarding and returning current conductors next each other -> cancel out each others' EM-fields.
    \$\begingroup\$ Good points, except 90 degree corners aren't usually that bad. It's probably not worth the effort to round off/chamfer most corners. \$\endgroup\$
    – Justin
    Commented Jun 18, 2013 at 11:52
  • \$\begingroup\$ To add to wha @Justin says, my experience is 90 degree bends are no problem up to 1 GHz or so. Also, isn't your 5th bullet item the same as your first bullet? \$\endgroup\$
    – The Photon
    Commented Jun 18, 2013 at 15:35
  • \$\begingroup\$ No they are not. In the first bullet the point is to keep area inside a conductor loop small -> induces smaller voltages from outer EM-fields. In the 5th bullet point is that in a conductor flows current that creates EM-field. In returning conductor approximately same amount of current flows and their EM-field sum together -> zeroing each other's EM-field. \$\endgroup\$
    – sailfish
    Commented Jun 19, 2013 at 15:00
