I would like to ask if anyone can help me with the following problem. I would like to print the output characteristics of the JFET-transistor in PSpice. This is PMBFJ309, here is the datasheet. My test setup looks like this.
And here is the output.
The values of Vgs goes from top to bottom, starting from 0V to -4V, the increment is 0.25V. But when you compare this result to a datasheet, it's completely different.
So my question is, is there any way to get the same graph as from the datasheet.
There are .model characteristics.
.MODEL PMBFJ309/PLP NJF
+ VTO = -2.3973E+000
+ BETA = 3.81468E-003
+ LAMBDA = 3.80761E-002
+ RD = 2.33008E+000
+ RS = 2.33008E+000
+ IS = 3.02702E-016
+ CGS = 6.50000E-012
+ CGD = 5.70000E-012
+ PB = 6.83767E-001
+ FC = 5.00000E-001
Thank you in advance.
