I am trying to build my own RGB + WW + CW led with 5050 leds and to make a prototype I bought some leds.
I have RGB leds and regular white ones, the RGB are kind of dimmed at the voltage from the next datasheet, but the white ones are really bright. I use my lab power supply and when i power the white leds at 2.9V, it draws 80mA, if i use 3.2V like the datasheet suggests, it draws around 150mA and at 3.6V (maximum from datasheet), it draws about 500mA
I connect all 3 pins to have the 3 leds together. Am i doing something wrong because i can't understand why it uses this much power
Datasheet: https://www.iled.com/class/INNOVAEditor/assets/YeniDatasheets/4050-4055-4057.pdf
