Is it possible to use a balance potentiometer to blend/split the coils of a humbucking pickup on an electric guitar?
A humbucking pickup is (basically) just two single-coil pickups placed close together in a noise cancelling configuration (single-coil pickups of yesteryear were notoriously willing to accept electrical interference, sending noise to your amp). I've seen many guitars with humbucking coil splitting options, but all of them are single option type, such as deactivating the inner coils of a pair of humbuckers with a push-pull tone pot, or more recently the push-push pot, still used as a tone pot.
Would it be possible to, instead, use a balance fader to control the output of the 2 coils in 1 humbucking pickup? If, for example, the fader was set in the center indent, it was a perfect 50/50 humbucker. Turned full left would give North coil only, full right giving South coil only, with fade in between.
