I have a device which provides a USB port. If I attach it to a Windows PC it is recognized as a "CP2103 USB to UART Bridge Controller". According to the device documentation, it should communicate in serial format at 38400bps.
I have to talk to this device with a atmega microcontroller.
Since the USB pinout is different from the serial UART of the uC, firstly I thought I would need a circuit to convert the signals.
I found the AVR-CDC project and put on a CDC-232 in order to convert USB (GND
, D+
, D-
, VCC
) to RS232 (TX
, RX
, GND
To make it I used another atmega328 as uC, flashed with the specific hex, with a 16Mhz crystal instead of the 12Mhz one specified into the diagram.
Then I built another piece of circuit to convert the RS232 signal to TTL:
So the signal conversion should be USB -> RS232 -> TTL.
I programmed my uC to send some data to the device and I can follow the signal with the oscilloscope until it enter into the CDC-232, then I lose it. I have no output on pins 4 and 5 of the CDC-232 uC, where I should have a USB signal.
Is my overall approach right? Sould I go on debugging the CDC-232 part or there is something wrong elsewhere?
