I know 3 EDA companies handle with SVSEED as the below image, enter image description here For reproducibility and random stability, I'd like to generate a random value by using "+svseed random" in SystemVerilog Cadence simulation as the below example snippet code,
class const_c;
rand bit [7:0] a;
endclass
module test;
const_c cons;
cons = new();
initial begin
    for(...) begin
       cons.randomize();
       printf("Current SVSEED: %0d", ?);
    end
end
endmodule
How do we know "svseed" value when "-svseed random" used. it's value in SystemVerilog?
  • \$\begingroup\$ For a simulation run you can pass svseed as an argument to the tool. Which tool you use? \$\endgroup\$
    – Mitu Raj
    Commented May 24, 2021 at 14:17
  • \$\begingroup\$ @MituRaj Cadence Xcelium, how do I get that value? \$\endgroup\$
    – Carter
    Commented May 24, 2021 at 14:18
  • \$\begingroup\$ If you used svseed flag, the value of seed should be the simulation log file. The default is value is 1 in some tools if you don't mention to the simulator. \$\endgroup\$
    – Mitu Raj
    Commented May 24, 2021 at 14:21
  • \$\begingroup\$ Is that only available in the simulation log file to get the value? because I'd like to make a directory each simulation by SVSEED value. and If I can get a SVSEED value in simulation time, it will be handy. \$\endgroup\$
    – Carter
    Commented May 24, 2021 at 14:25
    \$\begingroup\$ FYI, you have VCS and Questa switches swapped. \$\endgroup\$
    – dave_59
    Commented May 24, 2021 at 17:06
As far as I know, at least there is no direct method to find the root seed set by the simulator ahead of the simulation run. The value set by sv_seed flag is usually found in the log generated by the simulation. If not used, it's defaulted to 1 in some tools.
Because I'd like to make a directory each simulation by SVSEED value. and If I can get a SVSEED value in simulation time, it will be handy.
A work-around I have done in Questa-Sim in the past is generating a random root seed \$ R \$ in a script/makefile, and then create necessary simulation folders corresponding to this generated seed. Finally, invoke the simulation command from the script, and pass \$R\$ as argument using -sv_seed R flag.
