In order to maximize power transfer, and minimize signal reflection, one would impedance match between a output load and an antenna and between an input load and an antenna.
However, is there any impedance matching between the two antennas that is required to maximize power transfer? For example, if one has a 50ohm matched TX and a choice between a 75ohm or 50ohm matched RX, which would provide higher power transfer and why?
