I have a nucleo board but no mini-USB B so I hooked it up to an external STLink V2 programmer(related post).
The problems:
  1. At first it was working as expected but after a while STM32CubeProgrammer gives an error while trying to connect:enter image description here
  2. It works 1 out of ~20 tries, sometimes even more. When it works, it works fine. But the problem with plugging in again and again is, my laptop's USB port is becoming loose. I can already tell one of them is pretty loose already.
  3. I also tried holding the reset button and then trying to connect it, but same result(I have the reset pin connected, I don't think I needed to do that manually).
  4. I tried different modes, frequencies etc., to no avail.
What can cause this and how can I go about fixing it?
  • \$\begingroup\$ Have you tried changing your USB data cable? \$\endgroup\$
    – Dharmik
    Commented May 25, 2021 at 3:13
  • \$\begingroup\$ @dharmik There's no data cable. The STLink programmer connects directly to the female USB port. \$\endgroup\$ Commented May 25, 2021 at 3:34
  • \$\begingroup\$ Upgrade the St link firmware and USB drivers \$\endgroup\$
    – Sorenp
    Commented Jun 11, 2021 at 17:34
    \$\begingroup\$ @Sorenp I tried that already, didn't work. The actual problem turned out to be loose jumper wires. The STLink-jumper wire solution seems to be very finicky. I wish there was a big connector that attaches to the STLink end, that's always the problem. I have to hold the jumper wires firmly on the STLink and then it connects. \$\endgroup\$ Commented Jun 13, 2021 at 3:18
I had solved the problem within a few days of posting this question (before the very expensive usb cable I ordered online arrived) by shortening the jumper wires and soldering the ends of the wires to the connectors.
It seems that the cube programmer (and also the mbed studio I tried later on with bluepill and blackpill boards) fails to connect to the board using STLink devices if the jumper wires are even a tiny bit loose or are lengthy.
I know that the programming is probably done via UART and the corresponding UART baud rate doesn't seem to be too much for regular jumper wires to fail, still I have no idea why it doesn't work.
I would also like to add that I have used SPI and UART protocol faster than the mentioned baud rate reliably with the same jumper wires and a breadboard. It seems to be a STLink only issue.
Change "Reset mode" in STM32CubeProgrammer to different modes like:
I was getting the same error and I changed 'hardware reset' to 'software reset' and create "new project".
..my problem was solved
  • \$\begingroup\$ I had already tried that. Worked intermittently. The problem turned out to be the jumper wires. Using shorter wires and soldering them on both ends solved the problem permanently. \$\endgroup\$ Commented Mar 2, 2023 at 13:23
