I have a model for a solar array and a battery in MATLAB Simulink (simscape). and I would like to model a load given the power consumption over time. The load is connected to the battery the voltage of which varies due to charge and discharge. How can I do that?
  • \$\begingroup\$ Search for the keyword active load. Basically, use a transistor to draw a desired amount of current from the power supply. It will draw a proportional amount of power from the supply when supply voltage is regulated. \$\endgroup\$
    – AJN
    May 25, 2021 at 6:24
  • \$\begingroup\$ Instead of a circuit, you can also use an ideal current source (in this case, acting as a current sink) of the appropriate polarity instead of a load resistor if simscape has current sources. \$\endgroup\$
    – AJN
    May 25, 2021 at 6:25
If the battery voltage is v(t) and the instantaneous power consumption is p(t), then the current drawn must be p/v.
  • \$\begingroup\$ I tried that but it doesn't work for some reason. \$\endgroup\$ May 25, 2021 at 11:27
