I am working on a project that includes a scanning switch matrix. It also includes a joystick with an integrated push button. I am out of IO pins on the micro, but there are gaps in my switch matrix, so I would like to integrate the push button into the matrix. However, the button is permanently internally connected to the ground pin of the joystick.
I am pretty sure I can use an NPN transistor to connect the signal line from the push button across the matrix pins like I would a regular push button, but I want to make sure I'm not missing something important.
I sketched out something I think might work. R3 is the internal pull-up resistor in the micro-controller. For the other switches in the matrix, Q1 would be replaced by a N.O. switch with with series diode connected between ground and the output. I feel like my proposed circuit is backwards and will actually only activate when my push button is NOT pressed, but I think that would just need another transistor to invert that signal.
This is what the circuit looks like for a normal switch in the matrix (note that neither pin is locked to GND as is the case for the switch I am now trying to integrate).
The matrix scanning works by setting a single column low and the rest are tri-stated. Then all the rows are read in. It then switches to the next column and reads in again.
Does anyone have any better suggestions or corrections?
