I'm interested in building my own laser doppler vibrometer using laser diodes. The reason I mention laser diodes is because (1) I want it to be cheap and (2) I want to incorporate it into robotics projects. However, I'm unsure if it's possible to build something that satisfies my requirements for reasonably cheap (say, the components of such an LDV would cost < 500 USD). Specifically, I am trying to measure vibrations that have a frequency of 1 MHz – I am not trying to build a general-purpose measurement device, as most commercial LDV devices are. I was thinking of using self-mixing laser interferometry with a laser diode, but the research I've read seems to indicate that such self-mixing laser diode systems don't get anywhere close to 1 MHz. Is it possible to build such a reasonably cheap device? And, if so, how? I would greatly appreciate any references to research papers.
EDIT: I also read this Reddit thread from 8 years ago, where the OP seems to be trying to build their own LDV.
EDIT2: The distance the LDV would have to operate is very short (say, 1 meter or less).
    \$\begingroup\$ What lasers do you have at hand, in terms is line width? You say "reasonably cheap", but that sadly doesn't tell me whether you mean 50€ or 50000€ with that term... "Is it possible for me" is also sadly something we can't answer, as we don't know your equipment nor skill set! \$\endgroup\$
    – mmmm
    Commented May 27, 2021 at 8:18
  • \$\begingroup\$ @mmmm Let's say < 350€. I'm not so much concerned about skill required, as that can be learned. \$\endgroup\$ Commented May 27, 2021 at 8:20
    \$\begingroup\$ Edit your question, please. Also, this really seems unreasonably cheap, assuming you asking things this way implies you don't have a working interferometry setup lying around already. What do you have lying around already that helps with the task? I.e. of the Wikipedia diagram, which components are you missing? \$\endgroup\$
    – mmmm
    Commented May 27, 2021 at 8:21
  • \$\begingroup\$ @mmmm I have edited my post. I want to build a version of this from scratch that can be incorporated into robotics projects (which is why I wanted to use laser diodes). \$\endgroup\$ Commented May 27, 2021 at 8:25
  • \$\begingroup\$ @mmmm I assume the required optical elements are relatively expensive? In sum it would probably be a four digit number but could be doable below five digits? Ah, this self mixing device looks interesting.. but is that doable with a laser diode?? \$\endgroup\$
    – Ben
    Commented May 27, 2021 at 8:31
You are trying to build a 1 MHz center frequency vibrometer of unknown bandwidth with a range of 1 meter to an unknown target that will be mounted on a robot. You have a budget for materials of $500. I'm going to ignore the last part in the comments about using it to measure ultrasound in people since there isn't enough information to give a useful answer.
This seems entirely possible if you don't have to pay for your time. You can buy or make all of the components for a lot less than $500, except possibly for the computer that is going to process this data. You can buy a photodiode for a few dollars and make a transimpedance amplifier for a few dollars more. You can buy surplus modulators for tens of dollars and build your own RF drivers. At the coherence length you need (~2 m), laser diodes are a few dollars and drivers can be made or bought for relatively little. Since you don't care about the exact splitting ratio, you can use ordinary plate glass (tens of cents) for the beam splitters rather than precisely calibrated dilectric or silver beam splitters. You can machine or 3D print the optomechanics. You can build the A/D converter for tens of dollars and you could implement the mixing digitally in python which is free. That is probably less than one hundred dollars, so you have plenty left over to buy power supplies, optical filters, aluminum mirrors and lenses if you need them.
So yes possible, but you will probably spend orders of magnitude more on your time than you save by not buying commercial products.
  • \$\begingroup\$ Thanks for the answer. So would I be looking for a 40 MHz AOM and a 41 MHz photodiode? I'm not sure where to get the 41 MHz photodiode from, since 41 MHz seems to be a very specific number for it to be manufactured at. \$\endgroup\$ Commented May 27, 2021 at 20:24
  • \$\begingroup\$ Those numbers are just examples, but ~40 MHz is a relatively low speed so many typical photodiodes would work. If you find a different modulator, change those numbers. \$\endgroup\$ Commented May 27, 2021 at 20:35
  • \$\begingroup\$ So, for my application, the absolute numbers don't matter, just the relative numbers? Also, are there any cheaper options for modulators than acousto-optic modulators? \$\endgroup\$ Commented May 27, 2021 at 20:44
  • \$\begingroup\$ @ThePointer I suggested 40 MHz because it would be cheap. You can use other numbers if you prefer or find a good deal on hardware. \$\endgroup\$ Commented May 27, 2021 at 20:56
    \$\begingroup\$ @mmmm This is an interferometer, so the line width of the laser is irrelevant so long as the coherence length is longer then the optical path length mismatch between the arms. Reason is any phase on one arm will be subtracted from the other within one coherence length. \$\endgroup\$ Commented May 27, 2021 at 23:31
Maybe consider the principle that atomic force microscopes use.
They reflect the beam (very weak diode laser) off a vibrating object (in that case: the AFM cantilever) onto a quadrant photodetector.
After that you can condition the 1 MHz analog signal using standard electronics and ADC.
You don't necessarily need a quadrant photodiode, a differential one would also work. Or even a single one to some extent. The main advantage is cost, as you don't need an optical table and precision mounts. You also don't need to preserve phase of light as you do for interferometry. Therefore, you also don't need coherent light. So a well collimated LED will do.
  • \$\begingroup\$ Thanks for the answer. What makes you think that the way it is done for atomic force microscopy is relatively cheap and will work for 1 MHz? (I don't know anything about AFM.) \$\endgroup\$ Commented May 27, 2021 at 11:04
  • \$\begingroup\$ I suppose it will be cheaper because you don't need ultra-precise alignment as you will for interferometry. I don't know exact cantilever frequencies of AFM from the top of my head but i recall it is already in higher kHz range (mainly due to cantilever mech. resonance). Photodiodes and electronics work at much higher frequencies, so I see no reason why this won't work at 1 MHz. \$\endgroup\$
    – tobalt
    Commented May 27, 2021 at 11:07
    \$\begingroup\$ From what I've read, it seems that AFM works by using a photodiode to detect changes in light reflected off a reflective cantilever scanned over the sample in question. So, in other words, it requires a reflective surface, right? The surfaces that I will be working with will not necessarily be reflective. And one of the reasons LDV was so attractive was because it is non-contact, but this is lost in AFM due to the required contact (or close contact) of the cantilever. \$\endgroup\$ Commented May 27, 2021 at 11:19
  • \$\begingroup\$ Yes the AFM cantilever is polished on its back to be well reflective. To adopt this to dull object a mirror sticker would need to be attached. For interferometry to work well, your object also should be flat to within fractions of the wavelength over the spot size of the laser. But maybe LDV is different in this regard. I am not familiar with it \$\endgroup\$
    – tobalt
    Commented May 27, 2021 at 11:25
  • \$\begingroup\$ @tobalt An AFM for ~500 bucks? \$\endgroup\$
    – Ben
    Commented May 27, 2021 at 11:55
