I am designing the MIPS processor, this includes Data Memory and Instruction memory for testing.
I had a problem with IM synthesis covered in this question (How to make a synthesizable Instruction Memory in SystemVerilog?) and after rewriting it as adviced (ff with a case
statement) another problem occured.
The problem: Insruction in CPU has one cycle delay from the Program Counter. Thus, when branch instruction (number i) come, the Program Counter is already (i+1) and then come instr (i+1) and PC is PC_branch. How can I fix it? Delay is caused by this ff in IM. Code and waveforms are below.
The code:
always_ff @(posedge clk) begin
case (addr)
32'd0 : rom_ff <= 32'h2408000F; // a = F
32'd1 : rom_ff <= 32'h240A0000; // res = 0
32'd2 : rom_ff <= 32'h01485021; // (*) res = res + a
32'd3 : rom_ff <= 32'h2508FFFF; // a = a - 1
32'd4 : rom_ff <= 32'h1500FFFD; // if (a != 0) goto (*)
32'd5 : rom_ff <= 32'hAC0A0ADD;
default : rom_ff <= 32'h0;
endcase
end
