I'm using an STM32F765VGTx on a custom PCB with an external crystal (at 26 MHz), which however I can't seem to get working.
My first question, before any further detail, is: how can I find out if the crystal is actually oscillating properly and is not broken? (The PCB has been designed and assembled by another team - I don't know too much about electronics). I tried to configure a Master Clock Output line and attach it to an oscilloscope, but I only observe a 16 MHz signal if using the HSI, otherwise with the HSE I only see a steady logical high voltage. Here is the circuit:
Anyway, assuming the oscillator is working, here's my configuration (auto-generated by CubeMX):
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
/** Configure the main internal regulator output voltage
__HAL_RCC_PWR_CLK_ENABLE();
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 13;
RCC_OscInitStruct.PLL.PLLN = 96;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 4;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
Error_Handler();
PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_UART4|RCC_PERIPHCLK_SDMMC2
|RCC_PERIPHCLK_CLK48;
PeriphClkInitStruct.Uart4ClockSelection = RCC_UART4CLKSOURCE_HSI;
PeriphClkInitStruct.Clk48ClockSelection = RCC_CLK48SOURCE_PLL;
PeriphClkInitStruct.Sdmmc2ClockSelection = RCC_SDMMC2CLKSOURCE_CLK48;
if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
Error_Handler();
HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSE, RCC_MCODIV_1);
HAL_RCC_MCOConfig(RCC_MCO2, RCC_MCO2SOURCE_HSE, RCC_MCODIV_1);
Once the main loop starts, I can see that the HSE is not active and the HSI is being used instead with:
if (__HAL_RCC_GET_SYSCLK_SOURCE() == RCC_SYSCLKSOURCE_HSI)
HAL_GPIO_WritePin(LED_3_GPIO_Port, LED_3_Pin, SET);
else
HAL_GPIO_WritePin(LED_3_GPIO_Port, LED_3_Pin, RESET);
I tried entering debug mode and tracing the execution of HAL_RCC_OscConfig(&RCC_OscInitStruct)
, but once I reach the while loop that checks for an initialization timeout, the debugger hangs there and never gets out. Activating breakpoints right after the loop or at the line where the error would be returned, never stops the debugger, but I'm pretty sure this is a debugger issue since HAL_GetTick()
always returns 0. Letting the execution continue, however, eventually reaches the main loop (so it is not really stuck) but as I said it never switches to the HSE.
If anyone could help me find additional resources to learn more about the issue or could provide any idea to solve it, I'd be very grateful.
