I'm planning to build a "Test Fixture" which tests PCB via PC that reads data from the I/O module. And since i want this project to be flexible to the PCB change, my preference gone towards to the PLC ( I can easly extend the I/O number etc.). Using similar modules like "Analog Discovery 2" is seems not preferable cause of limited I/O. So I want to ask your advice on this subject. What can I use to read data from the tested PCB and communicates with PC (I don't want to build a PCB for it, since it seems not flexible)?
  • \$\begingroup\$ Have you looked at national instruments ni.com? they are one of many that make equipment specifically designed to do what you want. I used them many years ago and could not have been happier with the results. I believe they will also do one of a kind if you need that. \$\endgroup\$
    – Gil
    May 28 at 15:28
  • \$\begingroup\$ I have looked them but i was planning do this project more available in price aspect. If i cant find any option i will look the national instrument. \$\endgroup\$
    – U.Sim
    May 31 at 5:27
