High level
I'm trying to use an electronic drum pedal as an electronic drum trigger. My specific e-drum unit has only one pedal input, so I need to repurpose a drum trigger input in order to use more than one pedal.
The main issue is the pedal uses a membrane potentiometer, while the drums use a plain old piezo sensor so the outputs don't match.
The Pedal (Membrane Pot)
The pedal has a resting voltage of 256mV and uses a 33.2K membrane potentiometer. As you press down, the resistance approaches 0 ohm and voltage goes to ~6mV. From my research I've determined this is likely a voltage divider circuit? I've mocked it up and messed with the resistor values to get an approximate idea of how it works numbers wise -- no idea if this is correct, so it's just to give you an idea of where my head is at:
Here's a screengrab of an o-scope measurement of the curve from resting to fully pressed down:
The Drum (Piezo)
The drum appears to have a resting voltage of 0V, and when the sensor is activated it produces a negative voltage between 0V and -600mV which depends on how hard you strike -- lower the voltage the harder you hit.
Here is a screengrab of the curve from resting thru the strike and back to resting:
Summary
Basically I need to have the membrane potentiometer produce a negative voltage? Negative voltage is a new concept for me, so hopefully you can clarify what it actually means.
The naïve approach would be to slap a resistor in series to bring the pedal resting voltage down to 0V, and thus pressing it will produce negative voltage -- it makes sense to me from the standpoint of basic arithmetic but I'm sure things don't quite translate that way to the real world.
I'm a software engineer who is quite obviously green when it comes to electronics -- I think I know how to get the numbers, but not what they mean or how to manipulate them -- so any insight at all will be very helpful.
Thanks for your help!
