I need to connect this arduino mega to an external device (ANT BMS which has integrated Bluetooth), and I need to find out the address of the ANT BMS, in the provided iPhone app, there are no informations regarding the bluetooth address, so I wanted to use this arduino, which anyway in the end will stay connected permanently to ANT BMS
After I connected HC-05 module to arduino I issued the commands bellow :
I connected HC-05 to RX and TX pins of my mega and issued the commands in serial monitor (set to 38400 and Both NL & CR)
AT
// responded : OK
AT+ROLE=1
// responded : OK
AT+ROLE?
// responded : +ROLE:1
AT+INQ
// responded : ERROR:(16)
I also tried to send the AT+INIT but after that command the led starts flashing quickly and it does not accept any other commands :frowning:
AT+STATE?
// responded: +STATE:INQUIRING
// OK
    \$\begingroup\$ Does this answer your question? HC-05 Bluetooth AT+INQ command not working \$\endgroup\$
    – Mitu Raj
    May 31, 2021 at 10:20
  • \$\begingroup\$ No, That is what I first tried, but everytime after issuing the command AT+INIT command, the led starts flashing quickly and it does not responde to any other commands. I also tried AT+CLASS=0, no help. Does anyone knows why after AT+INIT the led starts flashing quickly, it does the same on your modules too ? \$\endgroup\$
    – ovisopa
    May 31, 2021 at 17:40
  • \$\begingroup\$ Today I tried again: AT+ORGL .... OK AT+RMAAD .... OK AT+ROLE=1 .... OK AT+CMODE=1 .... OK AT+INQ .... ERROR:(16) \$\endgroup\$
    – ovisopa
    Jun 3, 2021 at 17:04
  • \$\begingroup\$ The ERROR(16) means : SPP lib hasn’t been initialized. but if I tried AT+INIT, the led starts flashing fast and no commands are accepted anymore, for any command I write, I get no response from the module :( \$\endgroup\$
    – ovisopa
    Jun 3, 2021 at 18:00
