Over on the Home Improvement Stack Exchange there have been several questions noting that an LED light bulb or lamp glows dimly when only one of its AC supply wires is connected. Here, here, and here for example.
These are not examples of leakage through a switch that is never truly off like a dimmer or a "night light" switch that glows when off. These examples are all where the AC input circuit is open. One side of the driver input is connected to a wire that has AC voltage when (elsewhere) compared to ground or when compared to an (also absent here) other wire. But no ground, neutral or other wire is connected.
These are also not examples of residual power stored in the drivers' capacitors or of inductance from nearby power sources. In these accounts, the bulb turns off instantly when the single leg of the AC circuit is disconnected but remains glowing indefinitely if it remains connected.
Apparently, the LED driver is able to consume power from an open circuit. How? What is happening here? My vague theory is that some part of the driver is using the capacitance of the air around it as a current path. Does that make sense? I do not know how the internals of an LED driver work. If you take an 8th-grade science class view of this, there is magic going on.
My question is: what is really going on?
  • \$\begingroup\$ Does this answer your question? LED lamps keep glowing when dimmer is turned off \$\endgroup\$
    – winny
    May 31, 2021 at 13:14
  • \$\begingroup\$ No, that post does not answer my question. I was very explicit in the question to note that there is no dimmer or night light switch in the equation. The LED bulb is disconnected entirely on one side of its input. One of the questions I linked from DIY SE shows this clearly in a photo. \$\endgroup\$
    – jay613
    May 31, 2021 at 13:15
    \$\begingroup\$ Capacitive coupling in the cables or capacitive coupling via the person holding the lamp. No magic. Even more fun can be had if there is a powerful radio transmitter nearby. \$\endgroup\$
    – Kartman
    May 31, 2021 at 13:16
    \$\begingroup\$ Well aware that there is no dimmer. Your unconnected secondary/exposed wire will non the less have an area exposed which will capacitively couple to ground. Hence capacitive coupling and your LEDs glow despite being turned off. Try the same setup with DC instead and the problem will go away. \$\endgroup\$
    – winny
    May 31, 2021 at 14:17
    \$\begingroup\$ Some interesting reading: saazs.com/how-to-stop-led-lights-glowing-when-off \$\endgroup\$
    – Ama
    Jun 1, 2021 at 11:48
This is due to a leak from capacitive coupling. In short, a charged wire might be able to charge a little more if it is close to a conductive material (it "pushes" a little further the electrons of this material). By doing so, a slight current is induced in the live cable, which subsequently generates a magnetic field. If another non-live cable runs in its vicinity, it will catch some of this field and a slight current is now induced in the neutral: the current travels for a few milli seconds. But because this is AC, then the electrons moving to the right will start moving slightly to the left as soon as the voltage reverses; thus repeating the previous steps, and so on: you AC circuit is "closed". The effect increases when the cables get closer to each other, and/or when they run parallel for a long distance.
AC transformers take advantage of the magnetic field phenomenon : if you look at the circuit of an AC transformer you will realize the coppers of the high tension and low tension loops never physically connect to each other; yet supplying power to the high tension loop subsequently powers the low tension loop.
The electric field effect (letting the electrons move a little further) can be modelled by a capacitor "closing" the loop. Note I put this into brackets because, as per the transformer example, a capacitor only lets AC run through, not DC. Here is an illustration, unfortunately the comments are in French, but the schematics of the circuits are enough to illustrate the purpose. (full article here)
At the top you have a typical situation with two switches controlling the light for example from each end of a corridor: for the length of the corridor, you have two wires running parallel to each other. The schematic is the modelling of this situation.
Then the author of the article goes further: we add a real capacitor, shown in blue. Now, when the circuit is OFF, the leaking current goes through the LED and the capacitor: get a large capacitor and most of the current will prefer to go through it rather than the LED. When the circuit is ON, the capacitor is small enough that it rapidly gets fully charged, which means that the current then can only go through the LED. So choosing the right capacity of the blue capacitor is important: get it too low and you will not absorb the entirety of the leak, get it too high and you will needlessly waste power.
This effect was always there, but it is so small that incandescent bulbs would dissipate it before they became hot enough to produce light. With LEDs, which can turn on with only a few milliwatts, things are different and they do get sufficient power to glow a little.
    \$\begingroup\$ "Capacitive coupling" is the electric field. If the coupling uses the magnetic field then it is inductive coupling. \$\endgroup\$
    – JRE
    May 31, 2021 at 14:11
  • \$\begingroup\$ This is a great explanation of how this would happen if there is a two-way switch with a length of cable between them and both switches closed but opposite sides. I do not think all three of the examples I linked had two way switches. One of them clearly shows a photo of a bulb with one lead completely disconnected. The circuits are open. One of the linked questions is from you. In your situation is there a clear source of capacitance closing the circuit as in the diagrams above? +1 from me anyway as this goes way beyond blaming dimmers and hand-waving. \$\endgroup\$
    – jay613
    May 31, 2021 at 14:13
    \$\begingroup\$ The two-way switch is just an example of the many scenarios under which you might get this effect happening. First of, all cables have a capacitance even if very tiny. I sometimes like to model it as if the electrical system was a compressed air system: the air in the pipe between the LED and the dead end of the cable can be slightly compressed. Is this compression enough to make the LED glow? Maybe the AC LED transformer does also play a role here because it surely is made of a coil, for the purpose of transforming to the LED-friendly low voltage. This coil might generate a capacitance too? \$\endgroup\$
    – Ama
    May 31, 2021 at 14:23
  • \$\begingroup\$ @JRE I am not specialist enough to tell the difference. I updated my answer and tried to better break down the steps, but I'd be happy to hear you develop further. \$\endgroup\$
    – Ama
    May 31, 2021 at 14:38
    \$\begingroup\$ It is important to remember that there is no minimum current to turn on a diode, and the human eye is extremely sensitive, so for a simple resistive or capacitive dropper, even hundreds of picofarads of capacitive coupling between the circuit neutral can generate a faintly visible glow. Maybe less if you look very closely. \$\endgroup\$ May 31, 2021 at 15:52
So, what's a capacitor? Nothing but a pair of conductors, separated by an insulator. The particular characteristics depend on the shape of the conductors, their separation, the material properties of the conductors and insulator, and the overall shape of the assembly -- but any pair of conductors separated by an insulator, will exhibit some capacitance.
Now, what do you have with this single-wire-to-an-LED circuit? One conductor is obvious (the wire). The other conductor is either the neutral wire from this cable, the ground wire from this cable, or the earth ground below you. (Which is tied to the ground wire by an earthing rod, usually.) Yes, those wires or earth are very far away -- but they do exist. And the air and/or carpet and/or hardwood floor surface and/or subfloor and/or wood framing and/or drywall/sheetrock, is the set of insulators.
This parasitic capacitor is going to be a very tiny capacitance, meaning it will have a very high impedance at the 60Hz AC frequency (assuming you're in the US). Because impedance in the absence of other resistors is equal to the reactance, which is \$X_c = \frac{1}{2\pi*f*C}\$, with f in hertz and C in farads. C is very small and f is 60, so \$ X_c \$ is huge.
But the input voltage is pretty big too. So the current may not be negligible -- it may, in fact be enough to light up the LED.
Note that as \$ f \$ approaches zero, resistance approaches infinity; this is why if you apply DC to this circuit you will never see the LED light up.
This is basically what @winny said in a comment on the original question, but fleshed out a bunch. That comment got me thinking about this in the right frame of mind to understand what's happening.
