I'm looking for a rotary potentiometer that comes with a momentary push switch.
I came across this Bourns PTR90 potentiometer with rotary switch and I'm wondering how does the rotary switch works? It says 50 degree for switch activation angle in the datasheet. Does it mean the switch will be on when the position of my knob is at 50 degree?
I also saw this Bourns PDB183 potentiometer with push-pull switch. Is this a momentary switch or if I press them, it will stuck in the push position unless I pull the switch?
Thanks.
