I have a quick question on charging options for a 12S2P 18650 Li-Ion pack made of Samsung INR18650-35E cells. I have a pack built using a 12S balancing charging BMS (https://www.ebay.com/itm/233763643368). The design I'm building is already using a Mean Well MW LRS-350-48 48V 7.5A 350W Regulated Switching Power Supply for powering some other components. I would ideally like to use the Mean Well to also charge the battery pack if possible. I understand that charging the pack directly isn't really an option, but is it possible to put something like this:
I would wire this between the Mean Well PSU and the BMS? Obviously it has the low/high voltage limits, but is that going to provide good solution to maximize the longevity of the cells and the capacity? I'd just rather save the use of an additional power supply if possible. On a side note, the speed of charge really isn't a concern for me.
