Consider the RLC circuit below. enter image description here
In fact, it is a normalized filter with Butterworth approximation of 3rd order.
Now suppose that for some reason I am interested in the time domain formulation. Using KCL and KVL I ended up with these state equations:
\begin{gather} \frac{\mathrm{d}i_L}{\mathrm{d}t} = \frac{1}{L}(v_{C1} - v_{C2})\\ \frac{\mathrm{d}v_{C1}}{\mathrm{d}t} = \frac{1}{C_1}\left(\frac{v_{C1}}{R1} + i_L\right)\\ \frac{\mathrm{d}v_{C2}}{\mathrm{d}t} = \frac{1}{C_2}\left(\frac{v_{C2}}{R2} - i_L\right) \end{gather}
But when I am trying to get a transient response of these equations using some numerical integration scheme like Runge-Kutta or implicit backward Euler, the solution blows up.
Only for an initial condition \$(0,0,0)\$ it is zero everywhere. Whenever I try to put the different initial conditions, let's say \$(0.5,1,1)\$ it blows up.
Am I using initial conditions the wrong way? How to choose them correctly? I understand that by saying that for example \$v_{C1} = 10\$, it means that \$i_L = 10/(1||1)\$. Or is it even true? What is then \$v_{C2}\$?
    \$\begingroup\$ Simulate it in spice or some other transient package \$\endgroup\$ Jun 4, 2021 at 12:34
  • \$\begingroup\$ The initial voltages on caps and currents through inductors are independent of each other. \$\endgroup\$
    – ErikR
    Jun 4, 2021 at 12:57
  • \$\begingroup\$ which means that my equations are wrong but I cant see it. it is probably messing with this single current \$\endgroup\$
    – struct
    Jun 4, 2021 at 13:00
    \$\begingroup\$ When you say blow uo, please explain with a waveform. Zoom into the waveform of the values go to ranges above, say, 10 V. \$\endgroup\$
    – AJN
    Jun 4, 2021 at 14:35
I think the problem might be that your cap currents don't follow your +/- convention.
Here I've drawn all of the +/- indicators and current arrows:
The resulting KCL and KVL equations are:
$$ \begin{align} C_1\frac{dv_{C_1}}{dt} + \frac{v_{C_1}}{R_1} + i_L &= 0 \\ C_2\frac{dv_{C_2}}{dt} + \frac{v_{C_2}}{R_2} &= i_L \\ L\frac{di_L}{dt} &= v_{C_1} - v_{C_2} \\ \end{align} $$
Translating your equations back to KCL current equations I get: $$ \begin{align} i_{C_1} &= i_{R_1} + i_L \\ i_{C_2} &= i_{R_2} - i_L \\ \end{align} $$ which means the current arrows look like:
  • \$\begingroup\$ I made corrections according to your suggestions and now it works perfectly. Next time I must be more precise. Thank you, it helped me \$\endgroup\$
    – struct
    Jun 5, 2021 at 18:47
