The ideal parallel capacitor has been filled with 2 dielectrics as shown in the above diagram.
$$ V_{1} :=\text{potential at the top plate} $$
$$ V_{2} :=\text{potential at the bottom plate} $$
$$ V' :=\text{ potential at the border between the dielectrics } $$
$$ V :=\text{ potential at any point inside the any colored domain } $$
We want to deduce the formula of \$V\$
$$ D :=\text{ electric flux density } ~~ \leftarrow~~ \text{this value is constant at any point between the plates.} $$
$$ E_{1}=\frac{ D }{ \epsilon_{1} } $$
$$ E_{2}=\frac{ D }{ \epsilon_{2} } $$
The below 2 equations are the problems for me currently.
$$ V'-V_{1} = E_{1} d_{1}$$
$$ V_{2} -V'= E_{2} d_{2} $$
Concretely I can't get relations of magnitudes of the each potential.
Since
$$ E_{1} d_{1} ~~,~~ E_{2} d_{2} >0 $$
The below inequations must be held.
$$ V_{2} \geq V' \geq V_{1} \geq 0 $$
How can it be determined?
Why \$V_{2}\$ can be asserted that \$V_{2}\$ takes a highest value?
I thought the below.
$$ Q:=\text{charge at the top plate} $$
$$ \sigma :=\text{surface charge density of the top plate} $$
Since the electric flux density \$D\$ is constant at any point between the plates,
the surface charge density of the bottom plate can be said \$ -\sigma \$
By the way and needless to say , \$V'\$ is constant at any point inside the surface of border of the 2 dielectrics.
Of course electric lines of force mostly exist between the plates(few of electric lines of force exist outside between the plates).
What I've been missing or mistaking?
When you assumed $$ E_{1} d_{1} ~~,~~ E_{2} d_{2} >0 $$ you assumed the electric field points upwards. Therefore you assumed the bottom plate is at a higher potential than the top plate.
However, I don't see any reason you should assume the field points upwards.
It's probably better if you assume \$V_1\$ and \$V_2\$ are known values and use them to calculate \$E_1\$ and \$E_2\$. You might even decide that either \$V_1\$ or \$V_2\$ is taken to be 0 (i.e. is the reference potential) to simplify the calculations.
