I am trying to plot Vout against Vin(AC source) and I would like some reference on how to solve this kind of circuits using the constant voltage model for diodes. I am working though Razavi Microelectronics but I don't seem to get it. For example, if I assume that Vin < Vb then the diode is replaced by a VDon DC voltage source. Where do I go from there? Thanks
In these problems break the analysis into two cases -- when the diode is conducting and when it is not. When it is not conducting you can remove it from the circuit. When it is conducting you can assume the following:
  • it's voltage drop is 0.7V
  • the current must be flowing from anode to cathode
Case 1: The diode is not conducting.
We just have resistors and voltage sources and so \$V_{out} = (V_{in}-V_b)\frac{R_2}{R_1+R_2}\$.
Case 2: The diode is conducting.
Then \$V_x = V_{in}+0.7\$ and \$V_{out} = V_x - V_b\$, so \$V_{out} = V_{in} + 0.7 - V_b\$.
Now we have to determine for what values of \$V_{in}\$ the diode is conducting and when it isn't.
For the diode to be conducting we must have:
  • the current I has to be negative (flowing counter-clockwise)
  • the voltage drop across R1 is 0.7V
Note that the current \$I\$ is the current flowing through R1 plus the current flowing through the diode.
Translating these conditions into math gives us the condition: \$I < -0.7/ R_1\$.
Now use these three statements:
$$ \begin{align} I &< -0.7/R_1 \\ V_{out} &= IR_2 \\ V_{out} &= V_{in} + 0.7 - V_b \\ \end{align} $$ and you can come up with a condition on \$V_{in}\$ which tells you when the diode is conducting.
