I'm trying to figure out the best way to power my amplifier using either a battery OR a 230V power supply.
The amplifier has a wide input range that'll happily take the ~12V from the battery or the 24V from the power supply, but i'm not really sure about the best way to handle all of it.
What i want is for the power supply to take priority whenever it has power, so that the battery is only used when there's no mains power. Additionally i also have a battery charger that i want to keep the battery topped up when the amp is running on mains power and battery isn't used.
How do i isolate and switch everything properly? Obviously i would like to waste as little power on the whole isolation/switching as possible to save battery power.
Do i just litter the circuit with relays to switch everything?
My devices is the following: J1: 230VAC input jack PS1: 230VAC to 24VDC power supply for the amp PS2: Battery charger for the battery
