I'm looking for replacement button for Kensingtons "Orbit Trackball with Scroll Ring". I'm hoping to find at least something similar. Here is how the original button looks like:
Button dimensions
- Width: 6.2mm
- Depth: 6.2mm
- Height: 7.3mm
- Height (pressed): 6.8mm
- Pin size: 0.7mm
- Distance between pins: 4.8mm
There is symbols on top (can see on photo): 'J' and '2'. On the bottom "F3" and "TTC". It is possible to bent pins the way, that they will be sticking at one side, so button could be used as SMD.
