I bought a used Target/Threshold brand "Cheers" sign, however the power supply was missing.
The power supply was almost certainly a small battery pack. I am unsure about the operating voltage but I think it might be 5V. The lights use Edison/screw-in sockets with LED bulbs.
The sign has three strings of lights joined in series. The strings of lights use the same connector. The last connector, a pin connector/female, is where the power supply would connect. The connector is a small rectangular 2-pin wire to wire connector. It looks like this. 1 x 2 Pin Header 1 x 2 Pin Header 1 x 2 Pin Connector "Top" 1 x 2 Pin Connector "Top" 1 x 2 Pin Connector "Bottom" 1 x 2 Pin Connector "Bottom"
The most distinctive feature of the connector it the 2 raised half arrows on the "bottom" of the pin connector.
I do not have experience with electronic projects, but even I know I have seen it before. I just can not place it. After a good bit of searching I thought it was a type of JST connector. Unfortunately I could not find it on their website under either wire to wire or LED connectors.
The dimensions of the pin connector/female are as follows.
  • Width 5.65 mm
  • Height 4.75 mm
  • Depth 7.15 mm
  • Pitch @2.2 - 2.5 mm
My caliper blades are too big to fit inside the shroud around the pins to get an accurate measurement of the pitch.
Any help would be greatly appreciated.
  • \$\begingroup\$ * I am unsure about the operating voltage but I think it might be 5V* - then you must also be unsure about whether it was fed from a constant current source. LEDs normally are. \$\endgroup\$
    Jun 6, 2021 at 16:27
    \$\begingroup\$ Just cut it off and apply a connector of your liking?However if it used a battery pack, it most likely is not 5V. \$\endgroup\$
    – Justme
    Jun 6, 2021 at 16:32
It's a JST XH connector housing, Digikey part number 455-2266-ND
You can view a 3D model here:
https://www.digikey.com/en/products/detail/jst-sales-america-inc/XHP-2/555485?s=N4IgTCBcDaICwFYEFoxgGzuQOQCIgF0BfIA
If you look at page 2 of the XH datasheet:
https://www.jst-mfg.com/product/pdf/eng/eXH.pdf
there's this drawing of the housing:
For the XHP-2 the dimensions of A, B and C are:
and this aligns with your measurements.
