Hi I have a setup that I'm really going to simplify:
I have two questions about this setup:
- Why do I only measure 3V volts across the ground wire when I put 5 in?
- Is this proper grounding? I had issues before with this and the motor is definitely not getting the power it needs. I know its not an issue with the power supply because I got this power supply to work before, I just forgot how. I strongly suspect something is not grounded right.
