I created two always blocks in Verilog. In one always block, one bit register variable is flipping and in other always block, a counter variable is running. Now when counter will reach to a specific value I want to read the status of another loop variable. But couldn't understand the correct way to do it. Please help. Thank you for your time.
Verilog code:
module test1(
input enb,
input shift,
input customClk,
output out,
output intr,
input reset
reg [31:0] counter;
reg temp_out;
reg intr;
reg out;
always @ (posedge reset) begin
counter <= 32'b0;
temp_out <= 1'b0;
intr <= 1'b0;
end
always @ (posedge customClk) begin
counter <= counter + 1'b1;
if(counter==5000) begin
counter <= 32'b0;
out = temp_out;
intr = 1'b1;
end
end
always @ (*) begin
temp_out <= ~temp_out;
end
endmodule
Testbench code:
module test1_tb;
// Inputs
reg enb;
reg shift;
reg customClk;
reg out;
reg intr;
reg reset;
// Instantiate the Unit Under Test (UUT)
test1 uut (
.enb(enb),
.shift(shift),
.customClk(customClk),
.out(out),
.intr(intr),
.reset(reset)
initial begin
// Initialize Inputs
enb = 0;
shift = 0;
customClk = 0;
reset=0;
// Wait 100 ns for global reset to finish
#100;
reset =1;
if(intr) begin
$display("%b",out);
end
end
always #5 customClk = ~customClk;
endmodule
Simulation output:
