In a Grid Tie Inverter design, I need a circuit which can detect only one zero crossing of the Grid signal, (when the signal will change from negative to positive half cycle). I have made a circuit, which detects both the zero crossings. So please guide me, that which circuit will perform this function? I have made the circuit attached herewith, but it detects both the zero crossings.
1\$\begingroup\$ What about a divide by 2 like this? Also, harmonics causing extra crossings may goof you up. How about half-wave bridge instead of full? \$\endgroup\$– relayman357Jun 8, 2021 at 2:43
\$\begingroup\$ circuitdigest.com/electronic-circuits/… \$\endgroup\$– Bruce AbbottJun 8, 2021 at 3:08
1 Answer
You could use any safe method of illuminating an LED directly from mains which only conducts on one of the half cycles.
Two common arrangements are:
The LEDs represents the LED in the optocoupler.
The diodes are included to protect the LED from reverse voltage on the other half-cycle. You have to be careful in selecting the resistor value and the protection diode.
Target just a few milliamps -- perhaps even just 1 mA -- for the LED current. Also remember to do a power dissipation calculation for the resistor. You may need to go to a 1/2-watt resistor or use two resistors in series.
\$\begingroup\$ Thanks Mr. ErikR for your reply, but this circuit will not do that job, because the led will be on during the whole positive half cycle, so there would be a pulse equal to the duration of half cycle. I need a circuit which will generate an impulse, when the zero crossing before starting the positive half cycle appears. \$\endgroup\$– KamranmuJun 8, 2021 at 17:54
\$\begingroup\$ Usually events are described by transitions from HI to LO or LO to HI. A microcontroller, for instance, can generate an interrupt when a certain transition occurs on an IO pin. To translate an edge transition to a pulse look up "monostable multivibrator", for instance here. There are a lot of other implementations -- they are also called "edge detectors". \$\endgroup\$– ErikRJun 8, 2021 at 18:20
\$\begingroup\$ In fact, the circuit does generate a pulse -- the pulse is about 1/100-th of second long (assuming 50 Hz). If you want a different pulse length look up monostable multivibrator / edge detector circuits. \$\endgroup\$– ErikRJun 8, 2021 at 18:24
