Head over to Olimex, and they have a line of products called Olinuxino - with options based on ARM9 SoC (a Freescale i.MX 233 one running at 454MHz), ARM Cortex-A8 SoC (Allwinner A13) and I believe there are a few in the works based on even higher end SoC's (Cortex A9/A15).
One of the design guidelines of Olinuxino (as I understand) is that their board designs are hobbyist friendly, and for a better-than-newbie hobbyist, ability to do the PCBA using hand-soldering is part of such goals. I believe, all of their boards, are open-source HW, so that may be a good starting point.
Freescale ARM9's might be available on Mouser (or the other online distributors), but Olimex might be able to provide some hard-to-find parts, for example, they do sell the Allwinner A13 and it's matched power-management IC.
Anyhow, assembling a linux capable board requires access to tools, techniques, and skill, only fairly advanced hobbyists might have, and being able to design such a thing from scratch, IMHO, is not quite in the hobbyist territory.
Edit:
Yet another alternative could be something like ARM7TDMI SoC's, although they can only run ucLinux, I believe. I'd read somewhere that Linux kernel trunk had support for MMU-less processors added, which means, that a tiny distribution of standard Linux built for ARM7TDMI might also be feasible. Typically, ARM7TDMI's processors would be available in far more hobbyist friendly packages, with far fewer pins, and reference designs around them -- I'd expect to be far simpler. If you search for the like of Blueboard (IIRC!), you might find ready to use board, but also it's schematic.
PS> I got the ARM7TDMI thought, thanks to your ARM7 tag.
