my encoder has a CAN communication interface. I need 4 encoders for my application. However, my controller only has 1 CAN communication interface.
Assuming, the encoder has different CAN ID, will it be possible to read out all 4 encoder values by soldering the 4 CAN_H_{1,2,3,4} and CAN_L_{1,2,3,4} wires of my encoders to one CAN_H and CAN_L, respectively?
Planned circuit:enter image description here
    \$\begingroup\$ CAN is a bus for connecting multiple pieces of equipment together. I'd say yes but you need to provide the type and model, preferably a link to manuals, of the CAN controller and CAN encoders. You must also understand how to wire a CAN bus properly with terminations. \$\endgroup\$
    – Justme
    Jun 8, 2021 at 18:49
    \$\begingroup\$ Ah...in the circuit 120 ohm between CAN_L and CAN_H is missing... \$\endgroup\$
    – Joe
    Jun 8, 2021 at 19:01
Of course you can, that's why the CAN network is used on those encoders. But, you don't solder anything there, you buy a Y-splitter and prefabricated cables of specified lengths. Many different manufacturers do sell this cables. Read the manual of encoder and PLC carefully.
