I have an inductive sensor which measures the movement of a plunger. The plunger feeds with fuel an internal combustion engine. There is an interface where it is shown the movement of the plunger in mm and also I can read process value and electrical value.
What is the difference between these two terms? What is process value?
Sorry for the naive question, engineer here
  • \$\begingroup\$ Is this built into a fuel injector? \$\endgroup\$
    – Gil
    Commented Jun 14, 2021 at 2:58
An electrical value shall represent a measurement in electrical units, like volts, amperes, ohms, henries, farads,...
A process value is a value usually used in control loop. This may have physical units (mm in your case) or even without it. It's a common practice to use normalized values \$V^*=\dfrac{V_{input}}{V_{max}}\$ it would be 0.0 if Vin=0V and 1.0 (100%) if Vin=Vmax, without physical units.
