Ok so, I have a latching relay in my circuit and from what I have found online it should switch when I apply Voltage. So I should be able to get the relay to switch position if I connect one side to ground and the other to a switch which is connected to 5V (for this relay) I tried it like that and I cannot get my relay to switch. What do I need to do to get my latching relay to switch (link to the one I used further down)
(I am using a push button as switch but I also tried supplying voltage for longer and also tried changing the polarity)
(This is my first time using relays so sorry if this is a very newbie question, I couldn't find an answer online)
Link to the relay I am using: https://www.mouser.at/ProductDetail/KEMET/EC2-5SNU?qs=%2Fha2pyFadujLkLw4BdE1nEU29MmNgY0m7tndkTbYK3p3M5hspP5Ibg%3D%3D
Here is how I have it wired up (usb port is connected to a power brick which outputs 5V/1,5A DC, not exactly the correct current but it should still be good enough I think)
