This question is about whether an often-presented crowbar circuit is actually robust, or whether it is susceptible to triggering below the intended overvoltage condition. The crowbar circuit shown below, taken from Art of Electronics third edition, is commonly presented in datasheets, websites, and textbooks:
The triac gate is connected to the positive power supply through a fairly small (usually 220 - 330 Ohm resistor). Under normal operating conditions, when the overvoltage condition is not present, the TL431A has sufficiently-low leakage current that the resistor acts largely as a pull-up to keep the gate biased very close to the MT1 terminal.
In this post, the OP was simulating the configuration (but used different component values from the figure above), and ran into problems with the triac triggering at much lower power supply voltages than what was designed for. The accepted explanation was that the triac gate was getting enough current from the pullup resistor to trigger the triac.
If this explanation is correct, this seems like a very important shortcoming of this circuit configuration -- sensitivity to rather poorly-controlled and often unspecified parameters concerning the I-V characteristics of the gate terminal. Yet the configuration is very widely disseminated in respected sources.
So my question is whether this circuit as shown in the figure above is indeed a robust configuration, or does it in fact need additional components as suggested in the answer to the post referred to earlier? Or are there in fact other parameters on most triac datasheets that would enable the pullup resistor to be chosen reliably to avoid premature triggering of the triac? Some triac datasheets give a minimum value for the gate threshold current, as explained in this answer, but many do not.
  • \$\begingroup\$ In my experience, a triac needs very little bias current to hold it off... but in actual applications, it is highly sensitive to noise. In addition to the resistor, I'd add a capacitor from gate to ground to mitigate triggering on line noise. However, I'm not sure the simulation was accurate enough to pick up that propensity to premature provocation. \$\endgroup\$ Commented Jun 9, 2021 at 21:06
To put it bluntly, the explanation of the issue with the triac circuit is completely wrong in the first two sentences (I didn't read the rest).
The 330\$\Omega\$ resistor helps keep the triac "off". Note that it is MT1 connected to the positive rail, not MT2 (or the answer would be more correct). Replacing the resistor with a short would keep the triac from ever triggering (via the gate anyway, dv/dt or high temperature could still do it) (and the LM431 would be destroyed by overvoltage).
You have to assume the LM431 may take as much as 1mA before it begins to regulate properly (which is the situation just at the switching point). Typical is about 400uA. You need to consider the minimum trigger current of the triac. Such specifications are often pretty loose (maximum is typically well-specified). Some gate current will flow because of the LM431, and the job of the resistor is to keep that at a minimum.
Another factor that can affect both simulations and real circuits is the dv/dt as the circuit powers up. Very fast rise times alone can trigger the triac. A combination of factors (high temperature, some gate sub-trigger current, and high dv/dt) can lead to triggering.
Most triacs are fairly insensitive at room temperature so even the full 1mA is unlikely to trigger a triac under typical conditions (I'm not recommending this, just that it would typically reflect what a simulation should show). This insensitivity in a triac semiconductor design tends to go hand-in-glove with insensitivity to unwanted dv/dt triggering (for example when controlling an inductive load such as a motor or even a resistive load with a lot of inductance in the wiring), but there are probably other design factors as well.
    \$\begingroup\$ Thank you. The dV/dt point you make seems in particular like a real wildcard factor in a simulation, as we have no info from that post about how the solver arrived at the solution. The other curious observation in the post was that adding a small (50 mOhm) source resistance cured the simulation problem. This seems to cast more suspicion on details of the simulation than it does on a fundamental circuit configuration issue. \$\endgroup\$
    – user283168
    Commented Jun 10, 2021 at 13:36
Interestingly, I had a difficulty with the crowbar circuit - during the fairly rapid application of voltage possible with my application. It turned out (by monitoring with an oscilloscope) that the issue was NOT one of dv/dt triggering - but rather a very short delay (~5us) in the TL431 acheiving it's reference voltage. The result being that the TL431 was actually triggering the triac during power-up (by holding down it's gate as the power came up).
My solution (tested) was to add a 1k resistor into the gate lead, and connect a 0.1uF capacitor between the gate and MT1 - to form an RC delay sufficient to give time for the TL431 reference voltage to be established - when the circuit performance became excellent at catching deliberate overvoltage applications.
Unfortunately, this introduced a further issue because my downstream circuit is isolated by a schottky diode - so that the crowbar would not be exposed to extremely large capacitive currents. With very rapid removal and reapplication of the supply, the added capacitor obviously had insufficient time to discharge sufficiently to provide the needed RC delay needed for the TL431. A thoroughly tested solution was to add a 1uF capacitor across the supply upstream of the fuse. I was using BT137-600D triacs - and could repeatedly 'blow' 2-amp fuses (i2t of 21 A2s). Sorry - the '2' should be a superscript (square).
This not the answer. I will just show you a triac equivalent circuit when \$V_{T1}\$ > \$V_{T2}\$ (QIII third quadrant operation).
So that you could see the situation in a more clear way.
Additionally, you need to consider the gate threshold for a given triac used in the circuit in the third quadrant operation. And TL431 leaking current (\$100\mu A \:\:max ? \:\:or \:\:400 \mu A\$).
