Not sure how much is known or published about the back end of CircuitLab, but:
While simulating a different circuit, I noticed very long simulation time. I narrowed the culprit down to the below portion. With a DC sweep on V1 from 0V to 5V and a relatively large step of 0.1V it still takes several minutes:
Changing the Op Amp or BJT model didn't make a difference.
Simply replacing the BJT with a MOSFET speeds up the same simulation so that it runs in a fraction of a second.
Any ideas what's tripping up CircuitLab? Is it just that the BJT model implementation is more complex than the MOSFET?
(Please no answers telling me to use different software.)
  • \$\begingroup\$ Unfortunately I don't have a great idea, but I did notice that if you significantly increase the base resistance of the BJT (change R_B to be at least 10 Mohm) then the simulation is very quick. Seems consistent with the FET being faster. Did you try asking on the Circuitlab help forums? \$\endgroup\$
    – Halleff
    Commented Jun 10, 2021 at 19:46
  • \$\begingroup\$ What is the need of R3 in the first picture? \$\endgroup\$ Commented Jun 10, 2021 at 19:58
    \$\begingroup\$ @Circuitfantasist I guess it's not needed. I was tinkering around with it trying to see what might make a difference, and left it in to make sure it was a fair comparison to the MOSFET circuit. \$\endgroup\$
    – Theodore
    Commented Jun 10, 2021 at 20:10
(CircuitLab developer here.) It's much, much faster if you use the Op-Amp model without voltage rails:
From which I get the following plot in just a few seconds:
This slowdown is noted in the CircuitLab documentation:
If the op-amp will not be asked to saturate its output at voltage rails, using the op-amp component that doesn't have the rails will lead to faster simulation, and generally "behaves better" in terms of circuit convergence.
  • \$\begingroup\$ I can definitely work with this. The rest of the circuit should be keeping the output far from the rails. \$\endgroup\$
    – Theodore
    Commented Jun 10, 2021 at 20:17
  • \$\begingroup\$ Why is it so slow compared to Falstad’s? Even using an LM358 with rails? Try this on CL tinyurl.com/yjd9ubph or this tinyurl.com/yjop4azo \$\endgroup\$
    – D.A.S.
    Commented Jun 12, 2021 at 15:01
