this is my first post so I apologize if I do not follow any sort of convention.
I have researched how Center-Tapped Full Wave Rectifiers should work and from what I found, when the turns ratio is 1:2, then the voltage across each of the two inductors on the secondary side should be equal to the voltage input (Vin = VLS1 = VLS2).
I tried to model the circuit in LTspice, however my results were inaccurate as the voltages VLS1 and VLS2 are twice the input voltage. Could someone please point out where the circuit model went wrong?
Thank you very much.
