I'll try to explain everything with detail as this is one will be a hard one to explain.
Essentially what I am trying to achieve is sum both the left & right channel to produce a mono signal to be outputted via I2S as the subwoofer line.
The problem I am having right now is that after summing the samples and sending it back to the peripheral I am observing at least double the frequency compare to the input and I have no idea why. Also at lower frequencies the signal looks chopped (see pictures)
What I have done for you is:
- Ensured the I2S Clock is running correctly
- Without summing just sending 1:1 samples and it's a mirror image of the input
The I2S3 DMA is setup as follow:
- Length = 2048 (Tx_BUFF)
The I2S1 DMA is setup as follow:
- Length = 4096 (Rx_BUFF)
- Length - 4096 (Tx_BUFF)
Code: I2S_HALFCOMPLETE_CALLBACK()
void I2S_HALFCOMPLETE_CALLBACK() {
int * I2S3_TxBUFF = getI2S3_TxBUFF();
int INSAMPLE_I2S_MONO[1024];
for (int i = 0; i < 2048; i++) {
if ((i % 2) == 0){ // L Samples
INSAMPLE_I2S_MONO[i >> 1] = I2S1_RxBUFF[i];
} else if ((i % 2) == 1){ // R Samples
if (inputSourceMode == INPUT_INLINE) {
INSAMPLE_I2S_MONO[(i - 1) >> 1] += I2S1_RxBUFF[i];
INSAMPLE_I2S_MONO[(i - 1) >> 1] = INSAMPLE_I2S_MONO[(i - 1) >> 1] >> 1;
if ((i % 2) == 0) { // L Samples
} else if ((i % 2) == 1) { // R Samples
if (i < 1024) {
I2S3_TxBUFF[i] = INSAMPLE_I2S_MONO[i];
CODE: I2S_TRANSFERCOMPLETE_CALLBACK()
void I2S_TRANSFERCOMPLETE_CALLBACK() {
for (int i = 2048; i < 4096; i++) {
INSAMPLE_I2S_MONO[(i >> 1)-1024] = I2S1_RxBUFF[i];
INSAMPLE_I2S_MONO[((i - 1) >> 1) - 1024] += I2S1_RxBUFF[i];
INSAMPLE_I2S_MONO[((i - 1) >> 1) - 1024] = INSAMPLE_I2S_MONO[((i - 1) >> 1) - 1024] >> 1;
if (i < 3072) {
I2S3_TxBUFF[i - 1024] = INSAMPLE_I2S_MONO[i-2048];
UPDATE 1:
I still dont have a clue, but since the frequencies are being doubled, does it have to do with feeding the audio samples at half? For example I am receiving a total of 4096 samples but when summing I am only sending back out 2048. Is that why? Its trying to send 2048 within the 4096 sample period?
UPDATE 2:
Another gut feeling is coming from adding the two samples together. I feel like it has something to do with the sampling rate. Tried output L + R samples and it works fine, but when I combine them the sample rate is doubled.
double
on a microcontroller, that will just be terrible performance-wise, and you don't need it. So, let go of that code – and delete it. You're using git to track your code changes, anyway. Right? \$\endgroup\$
