Basically what the (unconventional) question says! I don't have a voltmeter at home. How can I fashion one, or use some kind of test to determine if current is flowing? I know it's a relatively low amount, so I'm not worried about hurting myself (I don't know how much current it will be), but I know that also may make it hard to tell. The device will likely be warm in general; it is powered by 5V. There will be other "outlets" on the device without voltage flowing that I can compare to. I don't care at all about the specific amount. I just want to verify whether it is or is not flowing (i.e. whether my code works), and I won't have access to the ideal tools over the weekend. Is this possible? Any ideas?
1 Answer
You could take a compass and place it over (or even near) one of your wires like in this blog post:
https://blog.doublehelix.csiro.au/confuse-a-compass-with-electricity/
It will deflect when current runs through the wire.
Here's a video demonstration:
https://www.youtube.com/watch?v=HcPDc23ZLEs
To enhance the deflection you can wrap the wire around the compass several times.
You can install a magnetometer app on a smartphone and use that in place of a compass.
If you don't have a compass or smartphone available, you can make a floating compass with a needle and a magnet:
https://www.youtube.com/watch?v=9EcKu9Oiot8
Don't have a magnet? Just use some silk or wool:
https://offgridsurvival.com/how-to-make-a-compass-in-the-wild/
\$\begingroup\$ super helpful! appreciate the huge range of household items. \$\endgroup\$ Jun 12, 2021 at 15:52
is
