The following problem can be found at the following URL: Some problems related to digital logic
It is problem number 26 on the webpage.
Problem:
Simplify the following expression using Boolean Algebra: $$ (X + Z)(\overline X + Y)(Z + Y) $$
Answer: \begin{align*} (X + Z)(\overline X + Y)(Z + Y) &= ( 0 + Z \overline X + XY + ZY )(Z + Y) \\ (X + Z)(\overline X + Y)(Z + Y) &= ( Z \overline X + XY + ZY )(Z + Y) \\ (X + Z)(\overline X + Y)(Z + Y) &= Z( Z \overline X + XY + ZY ) + Y( Z \overline X + XY + ZY ) \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X + XYZ + ZY + Y( Z \overline X + XY + ZY ) \\ % (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X + XYZ + ZY + YZ \overline X + XY + ZY \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X + XYZ + ZY + XY + ZY \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X + ZY + XY \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X + YZ + XY \\ \end{align*} However, the author of the problem has the following answer: $$ XY + \overline X Z $$ Where did I go wrong?
    \$\begingroup\$ In not drawing a Karnaugh map. \$\endgroup\$
    – user16324
    Commented Jun 12, 2021 at 22:37
Just continue from your last line $$ (X + Z)(\overline X + Y)(Z + Y) = Z \overline X + YZ + XY $$ and notice that $$ \begin{align} (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X (Y + \overline Y) + Z(X + \overline X)Y + (Z + \overline Z)XY \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X (\color{blue} Y + \overline Y) + Z(\color{red}X + \color{blue} {\overline X})Y + (\color{red} Z + \overline Z)XY \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X (\color{blue} Y + \overline Y) + (\color{red} Z + \overline Z)XY \\ (X + Z)(\overline X + Y)(Z + Y) &= Z \overline X + XY. \\ \end{align} $$
  • \$\begingroup\$ I do not understand how you dropped the term $Z(X+\overline X)Y$ in coming up with the line 2nd from the bottom. Please explain a bit more. \$\endgroup\$
    – Bob
    Commented Jun 13, 2021 at 1:24
    \$\begingroup\$ For any boolean value \$A\$ we have that \$(A + \overline A)=1\$. We also have that, for any Boolean value \$B = B \cdot 1 = B(A + \overline A)\$. So I used the expression you have on the last line of your answer and just added a bunch of multiplicative/AND 1's $$ Z \overline X 1+ Y1Z + 1XY $$ and then expanded those 1's with either \$X,Y\$ or \$Z\$ \$\endgroup\$
    – jDAQ
    Commented Jun 13, 2021 at 1:29
  • \$\begingroup\$ That I understood. I meant the line below that. \$\endgroup\$
    – Bob
    Commented Jun 13, 2021 at 1:32
    \$\begingroup\$ if you look at \$Z(X+\overline X)Y\$ half of it, \$ZXY\$, is implemented by the last term of the expression and the other half, \$Z\overline XY\$, is implemented by the first term. So I only "dropped" it because for any boolean value \$A\$ we have that \$A+A = A\$ \$\endgroup\$
    – jDAQ
    Commented Jun 13, 2021 at 1:35
You followed a good process. But perhaps the easiest way to see what you missed is to notice this:
$$\begin{align*} F &= Z\overline{X}+YZ+XY\\ &=Z\overline{X}+XY+YZ\\ &= \underbrace{\left(Z\overline{X}+XY\right)}+ \,YZ \end{align*}$$
The gathered up part (the left term of the last equation above) is just a mux:
If you feed in \$Z=1\$ and \$Y=1\$ then the mux output has to be 1. If you or into your equation \$+Y Z\$, this contributes nothing when that term is true because the only way that term is true is if \$Z=1\$ and \$Y=1\$. But the mux already yields that term, in that case. So the right term of the last equation above makes no contribution.
