I am coming to you for advice and I also need your help. I am working on a motor control board and for the debugging side I use a USB-C 2.0 connector and a module from FTDI, the FT230XS. Here is my question, I was wondering if I could power my FT230XS with my USB-C thanks to the VBUS pins? If so, do I have to add decoupling capacitors? And I would also like to know if for the CC1 and CC2 pins I need pull-down resistors, if yes why?
Thank you in advance for your answers.enter image description here
Certainly yes, the VBUS is precisely for the purpose of powering up connected devices.
You don't have to, but you can if you need cleaner power. Up to 10 uF will be fine.
Yes, you have to have 5.1k pull downs on CC1 and CC2 pins. Why? because it is the requirement of Type-C connector standard. Without pull downs the source won't output any VBUS voltage.
