I have a question about avoiding to use USB connectors on PCB design. Is there any way to connect a USB device to a board using another kind of connector? I mean, using a cable with USB-C port by one side and other kind of connector by the other side. In this case, it would be 3.0 USB connection.
EDIT: The target of this is saving space on the PCB (or trying to.)
EDIT 2: I was asking for a solution like this:
https://es.aliexpress.com/item/32966866664.html
Using a FPC connected to a mini board where is the USB-C connector, and the other side of the PCB connected to my own board on a FPC receptacle.
