MCU(ATMega 8 series) on my device has two operating modes
  1. Bootloader mode
  2. Normal operation
The firmware can be upgraded through MCU USART interface. To connect to PC I want to place FT232RL between PC and MCU. Device is normally powered up from external car power supply. During startup, MCU is checking certain GPIO pin and decides whether to enter bootloader mode or start normally. The question is what is the proper way to connect power bus of my device and USB/FT232 in order to have some output pin on FT232, which can be connected to MCU boot mode detection pin? That pin should have steady value once MCU/FT232 powered on from
  1. External power supply
  2. USB power
Basically there are 4 components a) MCU b) FT232 c) USB power bus d) External power bus
One power source is connected at the same time. I'm not sure if having one common power bus is good idea. Also I initially thought FT232 #PWREN pin can be connected to MCU for boot mode detection, but not sure if it will give me steady value.
Update:
enter image description here When USB is connected, MCU PB2 will have logical 1. When 12V is connected, MCU will have 0. Can this work or I missed something?
  • \$\begingroup\$ Check the FT232RL data sheet, there's a bunch of reference designs. I'm pretty sure dual power bus configurations are covered in there. \$\endgroup\$
    – Joe Baker
    Feb 5, 2013 at 1:17
  • \$\begingroup\$ It's hard to figure out solution I require from datasheet. \$\endgroup\$
    – Pablo
    Feb 5, 2013 at 9:47
  • \$\begingroup\$ Is it me or people on this SE site are down-vote happy. debbydowner.stackexchange.com anyone? – \$\endgroup\$
    – MandoMando
    Feb 5, 2013 at 15:46
I recommend you verify with FTDI datasheet as well as their support pages (they have a decent knowledge base). I have done a similar design:
You can use any of the CBUS pins of the FT232 to connect to the nBootmode pin of your chip. If the signal is the wrong way, then you can program the FT232 EEPROM to invert it. This means as FT232 powers up, it'll set those pins. You might want to employ a similar thing with nReset of your MCU, that way it'll remain in reset mode until FT232 is up and ready.
You'll likely need to manage separating the power bus using diodes such as a BAT54C or schottky diodes likes this: This one uses schottkys
Think about what would happen if both power ports are [accidentally] plugged in.
Regarding the PWREN#. It is meant for shutting down power of an external chip during USB suspend. It might be tricky in this case since it is low during USB enum, but it only goes high again during USB suspend which might prevent you from interacting with MCU. You might want use a generic CBUS IO and flick it up or down using the driver or one of the UART lines, etc.
Finally, most FT232 chips can't supply more than 50mA of current. Check that your MCU power requirement is lower.
  • \$\begingroup\$ Thank you. Is this the knowledge base? They have just few hardware articles. On topic: as I understand there are two stages. First when FT232 powers up, second when USB enumerates. I can use any CBUS pin, but I shall use PWREN to connect to nReset and DTR to nBootmode pin or is there any other signals I may connect? For separation do I just put BAT54C like this? My device is not going to use both powers at the same time. \$\endgroup\$
    – Pablo
    Feb 5, 2013 at 21:19
  • \$\begingroup\$ @Pablo added some more info with Diodes and PWREN#. You can flick other CBUS IO lines up or down through code that uses the driver as well. \$\endgroup\$
    – MandoMando
    Feb 6, 2013 at 20:52
