Basic problem: CPU instruction chooses which register to feed into a LU (such as an ALU), which then outputs a number somewhere and fed back into a register. But sometimes you want to feed the answer back into the same register. An example is Add RA and RB and store the answer in RA.
So trying to imagine that in my head just gets me stuck in an infinite feedback loop. So I searched around online for a relatively long time, but only got irrelevant stuff about what's inside an ALU.
I've done 4-bit and 8-bit adders before, even got the carry bit working. That's not what I'm looking for here. I'm looking for the architecture outside the LU that controls the inputs and outputs, and feeds it back to the registers. As far as I'm concerned, right now the LUs can be black boxes.
I decided to try to draw my own diagram and see how far I can get. (Click for higher resolution.)
In this example, I have four 4-bit registers, and four LUs. One of the LUs does only unary operations, so only takes one register as an input. The other three LUs do binary operations so they take two registers as inputs.
LU1 has one multiplexer guarding the input. 2 control bits choose which register to feed in. The other LUs have two multiplexers guarding their inputs. (Note that means you can "copy" one register into both inputs, so e.g., use Reg A and Reg A in LU2.)
The LU processes the inputs and generates an output. In fact, all LUs output their answer into another multiplexer, which has 2 control bits choosing which value to send to the final thing, which is a plus-shaped demultiplexer. 2 control bits choose which register to send that value to.
So finally we get to the problem. Storing the answer in Reg A, when Reg A was used as an input in the first place, is going to cause problems. Wildly varying states that might settle, might not. You could call this a racing condition.
Now I know "the obvious answer" is to use a clock to slow down the transmissions. But I don't know how to use it. Which parts need a clock? The MUXs? The LUs? The DEMUX? The Regs themselves? All of the above?
I also know there is a thing called the three-state buffer, but as far as I can tell it just uses impedance to "disconnect" a line, as if it's cut in half, so that the MUX or DEMUX is no longer driving (determining) the voltage state of the line.
I'm sorry this problem took many paragraphs to write out. I thought it was simpler to explain, but can't think of good ways to condense it. Hopefully someone can enlighten my architecture, or at least a link to a good diagram with control parts displayed and explained. I feel like I'm just missing one small critical piece that will make everything click.
