I'm trying to understand data sheets for flexible LED light strips. I'm looking at https://www.inspiredled.com/wp-content/uploads/2018/03/12V-SB-White-Flex-Spec-2.2.pdf, for example. It says:
To be installed in accordance with NEC, using Class 2 12V power supply only!
At the bottom of the subsequent table, it says:
Power Source | Max Length |
150W Transformer | 1046.5” (135W) |
Questions
Is a class 2 power supply limited to 100VA?
I've mostly dealt with DC, so I've forgotten a lot about VAs, but I'm roughly equating VA to Watt. Have I forgotten something important?
Wouldn't a 150W transformer power source violate the limits of Class 2?
Do strips like this do their own rectification so that they can be powered directly from a transformer?
Is using a switch-mode power supply rated 12V ⎓ 10A
Class 2? Is it more efficient than a transformer?
Does a Class 2 power supply require a UL or other NRTL symbol to be used in the US?
