9
I came, more or less accidentally, across this image here:
I understand all circuits and their resulting signal output, except for the last/lowest one. Shouldn't it look like this with one capacitor already? How has the coil to be understood physically/technically?
    \$\begingroup\$ You add a 2nd order Low pass in the last picture which will filter your AC-signal, \$\endgroup\$
    – Mike
    Jun 15, 2021 at 9:57
  • 8
    \$\begingroup\$ A very good image you found there! I wish all EEs in training would see it and think about why it is so. \$\endgroup\$
    – winny
    Jun 15, 2021 at 9:59
    \$\begingroup\$ @winny I'm even surprised that my question raised so much attention while I was thinking "Nah, that's so simple, you will be beaten up for asking this here.." :) \$\endgroup\$
    – Ben
    Jun 16, 2021 at 6:43
5 Answers 5
13
No, the waveforms should not look identical.
The added inductor and capacitor form an LC filter which filters out AC ripples and passes DC.
  • \$\begingroup\$ Thanks for the fast response! Ok, so instead, as I thought, it is not about smoothing (lifting the signal to a higher amplitude) but rather eliminating those "peaks/ripples" (lifting the signal to a lower amplitude)? \$\endgroup\$
    – Ben
    Jun 15, 2021 at 10:23
    \$\begingroup\$ @Ben both. The filter eliminates both high peaks and low "dips". \$\endgroup\$
    – fraxinus
    Jun 15, 2021 at 19:58
  • \$\begingroup\$ @fraxinus so it averages? :) \$\endgroup\$
    – Ben
    Jun 16, 2021 at 6:40
  • \$\begingroup\$ yes. Bear in mind that the result is still not an absolutely flat line. \$\endgroup\$
    – fraxinus
    Jun 16, 2021 at 6:45
    \$\begingroup\$ Also bear in mind that this LC filter only makes things smoother for a load with non-varying current draw (like a fixed resistor). When the current changes, you're going to see spikes in voltage (likely worse than the ripple) because of the LC filter's impulse response. \$\endgroup\$
    – Graham
    Jun 16, 2021 at 7:41
18
The last 2 circuits would only produce the same output (flat DC) if there is no load.
You can see from the 3rd circuit (bridge rectifier) that the capacitor only gets charged in 'pulses' - however, that load resistor is always drawing some current as long as there is at least some charge in the capacitor.
So if the capacitor is not getting charged (during a period of one of the 'dips') and the load is still drawing current, then the voltage on the capacitor must drop because it's being discharged.
This results in the rippled output you see in the 4th circuit.
In the 5th circuit, the energy stored in the inductor, combined with the 2nd capacitor, help to smooth out those ripples. The 2 capacitors and the inductor together form a 'pi' low-pass filter (named 'pi' just for the shape - no relationship to the mathematical value).
    \$\begingroup\$ These kinds of power supply circuits were used in vacuum tube equipment (low current, high voltage, and rectifiers that had limited tolerance for the inrush current of large capacitors...). Note that the chokes used were MASSIVE in value, often around 10 henry. Not microhenry. Whole henry. \$\endgroup\$ Jun 15, 2021 at 18:38
  • 4
    \$\begingroup\$ Is it safe to assume that the 5th circuit still won't produce a perfectly flat dc output under (reasonable) load, or is the filter good enough to eliminate ripples entirely for an acceptable load range? \$\endgroup\$ Jun 15, 2021 at 18:54
  • \$\begingroup\$ In some old radios, the speaker electromagnet (no permanent magnet) was doing double duty as the power supply choke. \$\endgroup\$
    – W5VO
    Jun 16, 2021 at 2:56
    \$\begingroup\$ @BrydonGibson if the noise/ripple frequency was perfectly matched to a zero of the filter, you could in theory have no noise, but in practice, there will be some ripple on the output, which you design to be small enough to be acceptable. \$\endgroup\$
    – mbrig
    Jun 16, 2021 at 5:31
6
As others have stated, the capacitors and inductors are commonly used for filtering out ripples by smoothing the peaks and valleys. There are lots of websites that explain the math formulas related to using these as filters. But fundamentally it's important to understand what's actually happening. Both of these components store energy, but they do so in different ways. Capacitors store it as static electricity. Inductors store it as magnetic flux.
This causes them to behave differently, and rather oppositely, to changes in voltage and current.
Capacitors try to keep the voltage the same at the expense of collecting or releasing as many electrons as it can manage. In an analogy of water, one can think of a capacitor as a pipe with a flexible membrane sealing the middle of the pipe. The pressure on one side of the pipe may go higher and lower, as compared to the other side of the pipe, and in doing so the flexible membrane will stretch back and forth to compensate for the pressure changes. Does the move the water on either side? Sure it does. This will be the alternating current "moving through". But does the water simply "flow" through the pipe? Not really. It's moving back and forth, but it can't actually flow through because of the flexible barrier sealing the middle of the pipe.
Inductors try to keep the current the same as the expense of collecting or releasing as much magnetic flux as it can manage. In the same water analogy, one can think of an inductor as a very long pipe, or tube. Anyone that has carried a pale of water up a hill can tell you that water has mass, or "weight", and things that have mass can also have inertia. Water, having mass, moving through a long pipe will have inertia. Any water in the pipe will want to remain still if it is already still, and will want to remain moving if it is already moving. The speed of the water in the pipe can speed up or slow down, but the inertia wants to keep the flow rate steady.
Put these two pipe systems together in a design similar to the filter circuit above and it will tend to behave the same way. As the source pressure increases or decreases, as from the pulsing DC voltage coming from the rectifier bridge, the first flexible membrane will stretch to absorb the initial increase in pressure. At the same time the long pipe will resist an increase in quantity of water, but will gradually allow it to increase. The second flexible membrane pipe will also stretch to absorb the pressure changes between the long pipe and the load.
This is what's happening in the "pi" filter above. The inductor is trying to keep the current flow steady, at whatever current flow it is currently at. The capacitors are trying to keep the voltage steady by collecting and releasing electrons from and to the circuit.
Generally speaking, adding more capacitors and inductors will result in better filtering, or less fluctuation. But like many things in life, there comes a point were more isn't better. At some point adding more components only increases cost, size, complexity, etc. There's also the continually nagging issue of working with imperfect components. An ideal capacitor or inductor will have exactly 0 ohms across it at any given voltage or current. But we make capacitors and inductors out of imperfect materials, so there is always going to be some amount of resistance added with these components. This resistance will cause some of the energy to be released as heat. Heat is wasteful and generally the enemy of any circuit, unless you are actually trying to build a heater. This tends to cause designer to add as many as needed and no more, or not much more.
    \$\begingroup\$ This is an interesting perspective, thanks for the input! P.S.: I think "enertia" is "inertia"? \$\endgroup\$
    – Ben
    Jun 16, 2021 at 8:44
    \$\begingroup\$ @dieselVtwin. thats a very detailed explanation. I have heard people criticize using the water apology to explain current and voltage. what in your opinion are the cons of using the water analogy? \$\endgroup\$ Jun 16, 2021 at 16:29
As noted by @rackanboneman in a comment to @brhans' answer, this kind of power supply LC filtering was common in the vacuum tube era, since at mains frequency (50/60Hz) the inductor coil was huge, because the inductance needed required heavy iron cores. Since that equipment already had huge and heavy transformers, adding a kg or so of coil wasn't a big deal.
That technique was somewhat "lost" in the transistor and IC era, where the total power requirement of the devices went down, so the mains transformers became much lighter and an additional heavy inductor became too bulky and expensive in comparison. Moreover, it was cheap and much easier to add regulator ICs after the first filtering cap to quench the ripple.
More recently, the LC filtering approach has come back in SMPSs, because of the higher switching frequencies at which the final rectification is performed (e.g. flyback SMPSs). Or even in transformerless SMPSs (e.g. DC/DC converters), because the ripple signal has a much higher frequency.
At frequencies of hundreds of kHz or maybe some MHz the filtering coil can be made fairly small and inexpensive, using specialized ferrite materials. This can improve ripple rejection quite substantially in some SMPS designs.
For example, here is an excerpt from TI's LM2576 datasheet (emphasis in yellow is mine):
sample power supply circuit from datasheet with LC ripple filter highlighted
  • \$\begingroup\$ Thanks for the background information! I would assume, whether using an IC or analog components depends on the usage? I think ICs are much more prone to fail due to external influences (temperature, radiation..)? \$\endgroup\$
    – Ben
    Jun 16, 2021 at 8:48
    \$\begingroup\$ @Ben ICs can do more than just fight ripple: ripple is a periodic signal superimposed to the output DC, it is not the only source of "bad regulation". Regulator ICs may provide several additional features, among which: regulation against load variations, input voltage variations, over-voltage/current/temperature protection, short circuit protection. \$\endgroup\$ Jun 16, 2021 at 8:56
  • \$\begingroup\$ @Ben Most applications that use ICs don't need additional ripple rejection (especially digital circuits), since the IC alone can keep it under control quite well. However, there are circuits (mostly analog stuff) in which even a smallish amount of ripple can be a problem. The LC circuit is a simple and cheap addition to SMPS to curb down ripple even more, if needed, without resorting to even more sophisticated circuitry (high-accuracy measurement instruments have a hell of requirements about noiseless power supply!). \$\endgroup\$ Jun 16, 2021 at 9:00
    \$\begingroup\$ @Ben If by "course" you mean "university course", this is something I can't answer because it is too country/faculty specific. What I told you is something which goes under the term/topic "power electronics" and, more specifically, "power supplies". "The Art of Electronics" renown book has a nice chapter on that (and that book is almost a must for every circuit designer). If you search the Internet for "power supply theory" and "power supplies" you should find a metric ton of information. The problem is sifting through it and choose the documents that you can grok with your skill level. \$\endgroup\$ Jun 16, 2021 at 9:52
    \$\begingroup\$ BTW, that chapter of AOE is available as a sample chapter on the official site here: chapter9. \$\endgroup\$ Jun 16, 2021 at 9:55
If you are only using line frequency, the inductors are at least 10x bigger size than the equivalent load power resistor. This is an old school way of attenuating 2x line frequency with a big power choke rather than a resistor in order to get 12Vdc from 12Vac rms. The inductor has a higher impedance that helps the bulk capacitor attenuate the 2x line frequency.enter image description here
Here is my simulation where you have sliders for load and L with a 12Vrms ideal source + bridge and CLC or “Pi” filter. Note that with 12V and 18W , you need a huge 100mH choke rated for 1.5A. The 1mF caps rated for 25V are also quite large. With the sliders on max load and max L (that I chose) the attenuation from 7.7Vpp to 167 mV = 0.0217 = -33 dB. now compare that with removing L to have 2mF reducing ripple only -3dB .
Have fun with the sliders for L and load, the. Compute L/R and RC for your required mVpp ripple! Or compute the impedance ratios for attenuation.
I have put in lots of probes to measure Vpp ripple, output power and voltage. The input is 12Vac rms.
This is why SMPS are so popular.
  • \$\begingroup\$ awesome, thank you! I need a while to understand, though :) But it's something to get started! \$\endgroup\$
    – Ben
    Jun 17, 2021 at 6:39
  • \$\begingroup\$ If you compute ZL and ZC using voltage divider Thevenin equiv’s you will see. But for an intuitive choice of values use the RLCf nomograph which I often show on this site. \$\endgroup\$ Jun 17, 2021 at 15:10
  • \$\begingroup\$ electronics.stackexchange.com/questions/369378/… \$\endgroup\$ Jun 17, 2021 at 15:11
