I am trying to choose between two sensor output types.
Either 0-10V or 4-20mA.
I am using the INA219B to measure current right now but I am wondering if getting a different output sensor would be more accurate.
I understand current and voltage are very different things but in this case they mean the same thing for me, how much load is on the pressure sensor (0-100% or level height.)
I am using a 1 ohm shunt resistor to measure the current for now but I can change this if it is a problem.
I am trying to measure very small changes (down to the millimeter or below of a column of diesel fuel) on a pressure sensor. The more accuracy or resolution I can get the better.
The basic calculations I have done are that to measure 1mm I either need to measure every 10mV or 16uA depending on what I choose (I am using a 1M sensor.) I am leaning towards every 10mV being the easier one of the 2 to measure.
I have also thought about changing this whole thing to a low noise temperature compensated op-amp design, but I have little or no idea where to start with that and as I only have 12V to work with I would only be amplifying the current in this situation to get an easier reading. As this runs off battery, I don’t like the idea of that.
If anyone has experience with measuring sensor output with the INA219B in both voltage readings and current your input would be a great help.
