I'm currently working on my first commercial design and this is the final prototype before I finalise the design, so I want to get it as correct as possible. My PCB has 12V, 5V and 2 x 3.3V(digital) and a separate 3.3V(analogue) rails. The reason for having 3 different 3V3 is due to power consumption, I'm using two MCUs and some analogue circuitry so a single 3V3 isn't viable if I need a heatsink.
FYI M3 is a DC-DC module with all the caps etc. on it. The final design will have a dedicated switching circuit.
12V-T isn't set in stone yet. This rail will be used for pulsing large current into a coil (1A+) but I may swap out U1 for 15V, 18V or 24V, I need to test experimentally with this board. Vtemp will be +3V from the regulator output depending on which voltage is decided. In this example it is 15V.
This design has a combination of sensitive analogue circuitry, digital circuitry with various voltage requirements and a large current pulsing circuit. I'm limited to a 4 layer PCB due to costs. I'm not splitting the ground plane as the consensus seems to be that there is no consensus and that you can actually make things worse. I intend to simply group all the separate circuitry (except the pulse) into their own areas and have them on the top layer. The second layer would be an unsplit ground. The third layer would be for the smaller voltage rails (5V, 3.3V etc.) and the bottom layer would be my pulse circuit: enter image description here
Q2A receives a clock pulse and J13 is a header that connects a coil of wire.
Now my questions:
  1. Does it make sense to separate the circuitry that has the large pulsing current and to place it on to the bottom plane, if the other circuits are on the top? This circuit generates large back EMF (250V+) across Q4 that is necessary for the design.
  2. Can I just have the 12V-T rail as large traces on the bottom plane alongside the circuit, rather than have it's own plane? Would this be better than having it as part of the dedicated power plane?
  3. If I dedicate the third plane for the other power sources/voltage rails, do I just physically split the copper plane in to sections and then connect to the corresponding components through vias?
Any ideas or advice would be appreciated. I've already got a good idea of what direction I want to go in but I want some confirmation/advice that I'm not doing anything obviously stupid.
  • \$\begingroup\$ What's connected to "CoilTX"? Could you make due to with a simple low side N-FET switch instead? \$\endgroup\$
    – winny
    Jun 16, 2021 at 12:32
  • \$\begingroup\$ Unfortunately no. Due to historical reasons and the way the coil is manufactured/connected to the board it has to be high side FET so one side of the coil is grounded at all times. \$\endgroup\$
    – ChrisD91
    Jun 16, 2021 at 12:49
  • \$\begingroup\$ I see. Just checking. \$\endgroup\$
    – winny
    Jun 16, 2021 at 12:52
How do you plan to pre-place your "boards"?
External connectors? On one edge? Two edges?
First assignments? Example : Two layers for supplies distribution (+5V, GND), as you have some connections... One layer for signals, One layer Gnd1 for ground signals (quasi no current, in general weak current).
Some cautions to follow: (not limited) Well and shortest decoupling of power supplies of every OPamps... Well and shortest decoupling of power supplies of every digital circuits... Keep geometric "area" of "high current conducting lines" as little as possible... Only one GND point connection for all "gnd", near GND general power supply, on side (15V)...
