I am new to electronics and I have a little trouble applying the basics I learnt so far. My problem is basically that I don't understand why we consider the second circuit below as the Thevenin equivalent, even though the behaviour of the transfer function is different.
Here you can see the parallel RC circuit.
The supposed Thevenin equivalent.
Blue is the parallel RC-Circuit and green the Thevenin equivalent. I think the behaviour of the two circuits is apparent. Also, if we derive the transfer function for the circuits, we get two different solutions.
Transfer function for parallel RC-Circuit:
formula
formula
Transfer function for thevenin equivalent:
formula
formula
formula
    \$\begingroup\$ Yes it should, did you forget to halve the voltage to get the same curve? \$\endgroup\$
    – Justme
    Jun 16, 2021 at 20:48
  • \$\begingroup\$ That's right. I should have seen that. \$\endgroup\$
    – jedect_13
    Jun 17, 2021 at 11:35
The voltage of the Thevanized circuit is only half that of the original.
  • \$\begingroup\$ Specifically, V2=V1/2 for proper representation. \$\endgroup\$ Jun 16, 2021 at 20:27
