is there a way with Eagle to check all the via ?
I want to be sure that they are all vias from 1-16 layers.
I found manually a via 1-15 ( my mistake during placing it )
Is there a way with the error/rule checking ?
I am working with Eagle 9.6.2. Eagle has changed quite a lot in the last 5 years so there may be some differences.
  1. Disable the option to place the vias that are not 1-16 in the first place. In DRC-> Layers remove the via options that you don't want. After that it should not be possible to use it. DRC->Layers
  2. Check the Manufacturing->Drills tab. All holes are displayed there and you may spot the intrudes here. Manufacturing->Drills
  3. After generating you gerber data, check the drilling files. There only should be drill file named something like this drill_1_16.xln. Any other files indicating that you may have buried vias.
